[mapguide-users] GoogleMap image on savemap o print map fusion
viewer?
Zac Spitzer
zac.spitzer at gmail.com
Wed Mar 23 20:26:41 EDT 2011
Currently, those fusion widgets only retrieve the first active mapguide map
and return an image.
In order to include a commercial base layer, you would need to write a custom
widget which is in this case google aware, which returns a single image using
the google api and then use the GD support in php to then overlay the
mapguide layer
z
On Thu, Mar 24, 2011 at 7:48 AM, Joel Nelson Epulef F <biogest at gmail.com> wrote:
> Hello,
> How include googlemap image on widget savemap or print map fusion viewer?
> Regards
> Joel
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
