[mapguide-users] MG 2.1 ServerConfig.ini Settings Check
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Fri Mar 25 11:49:36 EDT 2011
http://trac.osgeo.org/mapguide/wiki/ServerconfigWebConfigIni#ServerMaxConnections
Three questions if anyone can help with some performance tuning:
1) The recommended total MaxConnections is 62 for MG 2.1 (total of admin,
site, client)
But the default server config.ini has 100 MaxConnections for
[ClientConnectionProperties] is this just a bad setting?
Is this theoretical or could a regular few-core server hit this limit?
2) The recommended QueueSize is greater than (MaxConnections -
ThreadPoolSize)
But the default server config.ini for MG 2.1 has 100 MaxConnections and 20
for ThreadPoolSize for [ClientConnectionProperties] and only 40 QueueSize...
Is this going to do harm (or just theoretical)?
Should the MaxConnections for [ClientConnectionProperties] should just be 30
(keeping total to 60) and then the QueueSize 40 < (30 - 20)
3) Finally, I should know but can someone put into clear language the
difference between the [ClientConnectionProperties] and
[ServerConnectionProperties]
thanks - Crispin
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MG-2-1-ServerConfig-ini-Settings-Check-tp6208141p6208141.html
