[mapguide-users] Re: problem with tiled map - shown only in overview window !!!
Jackie Ng jumpinjackie at gmail.com
Mon Mar 28 07:18:38 EDT 2011
Does your widget set contain a CursorPosition widget named "CursorPosition"
and a ViewSize widget name "ViewSize"?
Each widget referenced in a container (toolbar, menu, context menu, etc)
must point to a widget of that name in the widget set. A common symptom of
broken widget references is them not showing.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/problem-with-tiled-map-shown-only-in-overview-window-tp6214081p6214499.html
