[mapguide-users] Invkoe URL with parameters
Jayanta
jayanta.ghosh at cesc.co.in
Wed Mar 30 02:55:55 EDT 2011
I want to invoke a url along with parameters. Using Mapguide I have
configured the invoke url and passed the parameter by providing the
key/value pair i.e SELECTION/$currentSelection. The url is basically an
asp.net page and its source code is given below:-
<%@ Page Language="C#" ValidateRequest="false" %>
<%@ Import Namespace="OSGeo.MapGuide" %>
String sessionID = Request.Form.Get("SESSION");
string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
String configPath = realPath + "webconfig.ini";
MapGuideApi.MgInitializeWebTier(configPath);
MgUserInformation userInfo = new MgUserInformation(sessionID);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
String selString = Request.Form.Get("SELECTION");
Response.Write(selString);
String selection = HttpUtility.UrlDecode(selString);
Response.Write("Selection=\n");
Response.Write(selection);
List Selection
The output that i am getting from the above page is also given below:-
%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22UTF-8%22%3F%3E%0A%3CFeatureSet%3E%0A%3CLayer%20id%3D%22e7fca9e2-ffff-ffff-8004-001cc0bbbc38%22%3E%0A%3CClass%20id%3D%22Default%3AOPTICAL_FIBRE_FINAL_polyline%22%3E%0A%3CID%3EAwAAAA%3D%3D%3C%2FID%3E%0A%3C%2FClass%3E%0A%3C%2FLayer%3E%0A%3C%2FFeatureSet%3E%0ASelection=
AwAAAA==
My requirement is that when i will select a layer in the map that selected
object has got some attribute, I want to capture the attribute value in a
variable.
I will be greatful if any body can help me in this regard.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Invkoe-URL-with-parameters-tp6222045p6222045.html
