R: [mapguide-users] Server Error in
'/mapguide/mapviewerajax' Application.
Francesco Sozzi
fsozzi at intercad.ch
Thu Mar 31 03:09:01 EDT 2011
Hi Zac,
I used 2.1.0.4283.
I already installed on 2003 server without any troubles. The only difference
here is that I installed .Net 4 (together with 1 and 2). I don't know if
this makes things different for MG...
As soon as I can, I would like to take a try with 2008 server. Do you think
MG will expose any problem with this version?...
-----Messaggio originale-----
Da: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Per conto di Zac Spitzer
Inviato: giovedì, 31. marzo 2011 01:48
A: MapGuide Users Mail List
Oggetto: Re: [mapguide-users] Server Error in '/mapguide/mapviewerajax'
Application.
which version of MapGuide ?
On Thu, Mar 31, 2011 at 10:27 AM, Francesco Sozzi <fsozzi at intercad.ch>
wrote:
> Hi all,
> I've just installed Mapguide on a Windows Server 2003.
> On that server I've also installed .net 2.0, 3.5 and 4.0 (I have
application
> on 4.0).
> I've also installed Maestro and when I try to browse any resource directly
> (layer, map, layout) from Maestro I get:
> Server Error in '/mapguide/mapviewerajax' Application.
> The resource cannot be found.
> Description: HTTP 404. The resource you are looking for (or one of its
> dependencies) could have been removed, had its name changed, or is
> temporarily unavailable. Please review the following URL and make sure
that
> it is spelled correctly.
> Requested URL:
> /mapguide/mapviewerajax/eurl.axd/2879cdc3a0e9a246b980c01c0a41791e/
> Version Information: Microsoft .NET Framework Version:2.0.50727.3053;
> ASP.NET Version:2.0.50727.3053
> If I try to open weblayout programmatically I get:
> Server Application Unavailable
> The web application you are attempting to access on this web server is
> currently unavailable. Please hit the "Refresh" button in your web
browser
> to retry your request.
> Administrator Note: An error message detailing the cause of this specific
> request failure can be found in the application event log of the web
server.
> Please review this log entry to discover what caused this error to occur.
> I checked log for both IIS and MG but not found any interesting info.
> Another strange thing is that after receiving the last error message my
IIS
> seems busy and I have to run iisreset.
> Any suggestions?...
> Best regards
> Francesco
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
