[mapguide-users] RE: [mapguide-internals] How to connect MapGuide
Open Source Server (2.1) to MS SQL 2008 Server DB
Martin Morrison
martin.morrison at edsi.com
Mon May 2 09:41:58 EDT 2011
Which version of MS SQL? Spatial data (geometry/geography)? Or simply data that needs joined to other geometries stored elsewhere?
(I forwarded my response to the correct list for you).
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA 24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Leendert Ramaer
Sent: Monday, May 02, 2011 9:37 AM
To: mapguide-internals at lists.osgeo.org; cst.keet at amersfoort.nl; la.ramaer at amersfoort.nl
Subject: [mapguide-internals] How to connect MapGuide Open Source Server (2.1) to MS SQL 2008 Server DB
Dear listmembers,
Installed the free MapGuide OpenSource (version 2.1) today om my webserver (Apache).
I don't know how to connect to the MS SQL database which is operating on it's own database server.
The MapGuide server is working properly on my local network..
There are plenty FDO-providers installed with the data, so that's not the problem..
Do I need to edit certain .dll files in an config or other xml file, to make the connection complete?
Much help is appreciated as I don't have any idea..and I haven't found any helpful guide..
Thanks in advance.
Regards,
Leendert _______________________________________________
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
