[mapguide-users] Re: ODBC Connection
Martin Morrison
martin.morrison at edsi.com
Thu May 12 09:28:56 EDT 2011
Understood.
"...crap in a map :)"
Understood again for effect...<G>.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA 24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Von Barth, Peter
Sent: Thursday, May 12, 2011 9:03 AM
To: MapGuide Users Mail List
Subject: SV: [mapguide-users] Re: ODBC Connection
Good Idea!
But.. how and where people in this company decides to document things is out of my hands. My job is just to display their crap in a map :)
-----Ursprungligt meddelande-----
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Martin Morrison
Skickat: den 12 maj 2011 14:28
Till: MapGuide Users Mail List
Ämne: RE: [mapguide-users] Re: ODBC Connection
Why not just avoid the hassles and use a real database? MS SQL, MySQL, Oracle, etc... All of these have free versions that would be far more robust.
Martin Morrison
Roanoke, VA 24018
540.345.1410
gis.edsi.com
Sent: Thursday, May 12, 2011 8:21 AM
Yes I installed the 64-bit version.
I had to rollback the 2.2 installation. And before I try it again I need a few clarifications.
In your blog you mention that in office 2010 odbc drivers... we have 2007 installed in the office. Does it still apply?
Alongside Meastro3 I also have MapGuideStudio 2009 and here it´s possible to chose to connect to
(*.mdb) which gives me a connection string like:
Driver={Microsoft Access Driver (*.mdb)};Dbq=%MG_DATA_FILE_PATH%ABB_stationer.mdb;Uid=;Pwd=;
Or (*.mdb,*.accdb) giving me
Driver={Microsoft Access Driver (*.mdb, *.accdb)};Dbq=%MG_DATA_FILE_PATH%ABB_stationer.mdb;Uid=;Pwd=;
This didn't work.
Do I need to install the 64-bit drivers for Micrsoft Access Databases on my machine where MapGuide is running? Will that help? Or do I need a complete office installation, which I don't have?
/Peter
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Jackie Ng
Skickat: den 12 maj 2011 12:45
Till: mapguide-users at lists.osgeo.org
Ämne: [mapguide-users] Re: ODBC Connection
Did you install the 64-bit version of MapGuide?
If so, you have to tweak the connection string (either via the XML Editor,
or by the RawConnectionString mode in the ODBC editor) so that it uses the
Microsoft Access 2010 ODBC drivers. Maestro can't do this automatically for
you because there's no way currently to determine the "bit-ness" of the
MapGuide Server it's connecting to.
More info on my blog:
http://themapguyde.blogspot.com/2010/07/connecting-to-ms-access-databases-with.html
As for the Unmanaged sub-editor not working in Maestro 3? Yeah that is a
defect which I'll look into.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ODBC-Connection-tp6355171p6355267.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
