SV: SV: [mapguide-users] Re: ODBC Connection
Von Barth, Peter Peter.vonBarth at eon.se
Fri May 13 10:57:15 EDT 2011
Thanx for the help so far.
I'm now able to connect to the database. But when trying to view data or Feature there's 0 Entries in the database.
The Properties are there and the property types are as they should but there are no entries.
Something I Can do?
can I keep the 2.2 installation but change the odbc FDO back to the previous version?
/Peter
-----Ursprungligt meddelande-----
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Jackie Ng
Skickat: den 13 maj 2011 03:42
Till: mapguide-users at lists.osgeo.org
Ämne: Re: SV: [mapguide-users] Re: ODBC Connection
Yes you have to install the drivers where the MapGuide Server is running.
64-bit access drivers does not exist for Office 2007
Now here's the painful part. To install Access 2010 64-bit drivers on a
machine with Office 2007 installed, you have to uninstall Office 2007 and
then reinstall it after the drivers are installed. If Office 2007 is not on
that machine where MapGuide is installed, you can skip this :)
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ODBC-Connection-tp6355171p6357829.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
