[mapguide-users] Connection-problem-SQL-Server-2008
Martin Morrison martin.morrison at edsi.com
Tue May 31 08:27:38 EDT 2011
What were you doing when the error came up?  Custom code?
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of yash227
Sent: Tuesday, May 31, 2011 2:21 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Connection-problem-SQL-Server-2008
hi.. I fase this error !!! My spatial data in SQL2008
<2011-05-31T11:43:39> 	MapGuide Maestro API v3.0.0.5728	127.0.0.1
Administrator
 Error: An unclassified exception occurred.
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpSelectFeaturesSpatial.Execute line 110 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
  - MgServiceOperation.EndExecution line 533 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\base\ServiceOperation.cpp
  - MgServerDataReader.Serialize line 792 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDataReader.cpp
  - MgServerDataProcessor.GetColumnDefinitions line 120 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDataProcessor.cpp
  - MgServerDataReader.GetPropertyCount line 103 file
Yash
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Connection-problem-SQL-Server-2008-tp6421528p6421528.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
