[mapguide-users] Re: Client side way to get FEATID's from FDO?
Martin Morrison martin.morrison at edsi.com
Wed Nov 9 12:18:34 EST 2011
2 comments.
First, do I read this correctly that you are updating each move every time the user hits the arrow key?  If so, don't do that.  Let the user click once where they want it to go and move it once.
Second, 250 indexed records should be smoking fast.  Are you sure you have the code written efficiently and the database optimized?
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of tmblackflag
Sent: Wednesday, November 09, 2011 12:13 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: Client side way to get FEATID's from FDO?
FEATID is an identity property and lives in a RDBMS. It is a primary key and
is indexed and table is only 250 records right now.
It takes a total of 7-8 seconds to post to the db, get the feat id, then
connect to the DB to update the coordinates for the associated label point.
What i was really trying to do was give them 4 directional arrows so they
could move label points as they please. Since this is slower, I may have
them select the label point they want to move, then digitize a new landing
point and then update the existing record. That would probably be faster
than using arrows to move the point a few x/y coordinates at a time.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Client-side-way-to-get-FEATID-s-from-FDO-tp6976596p6978659.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
