[mapguide-users] Re: MapGuide 64 Bit Apache
Jackie Ng jumpinjackie at gmail.com
Wed Nov 9 21:28:16 EST 2011
We keep the binaries for Apache under the Installer.
http://trac.osgeo.org/mapguide/browser/branches/2.2/Installer/Support/Web/x64/Apache2
IIRC, these binaries were sourced from apachelounge. Memory is a bit fuzzy.
It contains headers/libs as well, so you should be able to build your httpd
modules against this if need be.
Note that trunk version of this is currently empty because of some yet to be
completed installer work.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MapGuide-64-Bit-Apache-tp6980282p6980338.html
