[mapguide-users] Does MaestroAPI v2.1 work with MapServer 2012?
hm
hm at geograf.dk
Mon Nov 14 08:28:13 EST 2011
Hi MapGuide Users
A quick question. Should the MaestroAPI v2.1 work against a MapServer 2012?
I fail to get it to work.
When I load a map (Both map, layer and data source are defined with schema
1.0.0) with an SDF or MapInfo TAB file data source I get an exception on the
FID column. When I debug the MaestroAPI source code I discover that all
columns from the data source defined as "int" are reported as
UnmappedDataType in the MaestroAPI. The API breaks when calling
CreateRuntimeMap on the connection, the exception is thrown in the
ConvertNetTypeToMgType because the UnmappedDataType is not handled.
Best regards
Hans Milling
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Does-MaestroAPI-v2-1-work-with-MapServer-2012-tp6992462p6992462.html
