[mapguide-users] MGOS 2.2 crash with WMS
Zac Spitzer zac.spitzer at gmail.com
Tue Nov 15 19:55:24 EST 2011
there has been a lot of work recently by AutoDesk on the WMS
side of things, which probably has fixed this problem. That code
hasn't been formally released yet, but it's available in svn.
Are the WMS services public? Ideally if you could provide a MGP sample
Does the error occur with both fusion (flexible) and the ajax (classic) viewer
On Fri, Nov 11, 2011 at 9:52 PM, Sal <opc_1 at hotmail.it> wrote:
> Hi all,
> I migrated my application from MGOS 2.0.2 to MGOS 2.2 because I need to get
> raster images from 2 different WMS services.
> I installed MGOS 2.2 on CentOS  5.3 server, but using my application I get
> random crash of MGOS. I analized error.log but, strangely, there isn't any
> error about crash.
> After many test of my application I found that map with 2 WMS or also just
> one WMS causes a crash after some selecting/deselecting cycles of all
> layers. The same map without WMS works fine. In the WMS request I must
> specify "version=1.1.0" for the first WMS service and "version=1.1.1" for
> the second WMS service.
> Part of the layers get data from MySql DBMS 5.1, the other ones get data
> from shape files (all together there are 12 layers).
> The coordinate system of map is Lat/Lon WGS 84. Also WMS maps are in
> EPSG:4326.
> About configuration:
> CentOS 5.3
> MGOS 2.2
> MGOS 2.2 bundle version of Fusion and Apache
> FDO 3.5
> DB MySql 5.1
> I attached to this post the error.log and trace.log.
> Can anyone help me?
> Thanks
> Salvatore
> http://osgeo-org.1803224.n2.nabble.com/file/n6985005/Trace.log Trace.log
> http://osgeo-org.1803224.n2.nabble.com/file/n6985005/Error.log Error.log
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/MGOS-2-2-crash-with-WMS-tp6985005p6985005.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
