[mapguide-users] Unable to get string value in properties pane
T.kiran kumar reddy kiranreddy.hcu at gmail.com
Fri Nov 18 08:21:29 EST 2011
i am using mapguide enterprise 2010 and mapguide studio. asp.net 3.5 with
iis5.0 vertion. while i am creating package i added one property by joining
two tables from the same resource(same database). after join data is look
like this as show in below image
http://osgeo-org.1803224.n2.nabble.com/file/n7008226/1.jpg
while i am click the property in layout i am not getting the
master_blockblock which is string(100) in data. this value is not getting
for every property. i attached the
http://osgeo-org.1803224.n2.nabble.com/file/n7008226/2.jpg
the same join i did in my database i am using sql server 2008r2 i am getting
the values for block.
any body pls help on this
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-get-string-value-in-properties-pane-tp7008226p7008226.html
