[mapguide-users] Installer MGOS 2.1 / 2.2
psciga scigalla at battefeld.com
Fri Nov 18 10:13:24 EST 2011
Hello,
since 4 houres I try to install MGOS 2.1 (alternativ 2.2) continous with the
same error:
"Product: MapGuide Open Source 2.1.0 -- Error 1335. The cabinet file
'MapGuideOpenSource.cab' required for this installation is corrupt and
cannot be used. This could indicate a network error, an error reading from
the CD-ROM, or a problem with this package."
The files MapGuideOpenSource-2.1.0.4283-Final.exe and
MapGuideOpenSource-2.2.0.5705-Release.zip are downloded today. Checksums are
ok.
After the 3. trial I installed MGOS 2.0.2. perfectly.
After uninstall the same result for 2.1 as before. What is wrong?
Please help!
Best regards
Peter
The system:
XP PRO, SP3
32 bit
Admin
antivir: off
firewll: off
Windows Installer 4.5
.Net Framework 2.0 SP2
.Net Framework 3.0 SP2
.Net Framework 3.5 SP1
.Net Framework 4 Extended
.Net Framework 4 Client Profile
IBB INGENIEURBÜRO BATTEFELD
AutoGIS mit MapGuide Open Source
Bad English? German user.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Installer-MGOS-2-1-2-2-tp7008577p7008577.html
