[mapguide-users] MGOS 2.2 crash with WMS
Zac Spitzer zac.spitzer at gmail.com
Tue Nov 22 09:59:33 EST 2011
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc95
http://trac.osgeo.org/mapguide/ticket/1392
On Wed, Nov 23, 2011 at 12:59 AM, Andreas Morf <a.morf at fkl.ch> wrote:
> Hi Zac
> Can you provide a hint where to look for these wms improvements in svn?
> Thx, Andreas
>> -----Ursprüngliche Nachricht-----
>> Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] Im Auftrag von Zac Spitzer
>> Gesendet: Mittwoch, 16. November 2011 01:55
>> An: MapGuide Users Mail List
>> Betreff: Re: [mapguide-users] MGOS 2.2 crash with WMS
>> there has been a lot of work recently by AutoDesk on the WMS
>> side of things, which probably has fixed this problem. That code
>> hasn't been formally released yet, but it's available in svn.
>> Are the WMS services public? Ideally if you could provide a MGP sample
>> Does the error occur with both fusion (flexible) and the ajax (classic)
>> viewer
>> On Fri, Nov 11, 2011 at 9:52 PM, Sal <opc_1 at hotmail.it> wrote:
>> > Hi all,
>> > I migrated my application from MGOS 2.0.2 to MGOS 2.2 because I need
>> to get
>> > raster images from 2 different WMS services.
>> > I installed MGOS 2.2 on CentOS  5.3 server, but using my application
>> I get
>> > random crash of MGOS. I analized error.log but, strangely, there
>> isn't any
>> > error about crash.
>> > After many test of my application I found that map with 2 WMS or also
>> just
>> > one WMS causes a crash after some selecting/deselecting cycles of all
>> > layers. The same map without WMS works fine. In the WMS request I
>> must
>> > specify "version=1.1.0" for the first WMS service and "version=1.1.1"
>> for
>> > the second WMS service.
>> > Part of the layers get data from MySql DBMS 5.1, the other ones get
>> data
>> > from shape files (all together there are 12 layers).
>> > The coordinate system of map is Lat/Lon WGS 84. Also WMS maps are in
>> > EPSG:4326.
>> > About configuration:
>> > CentOS 5.3
>> > MGOS 2.2
>> > MGOS 2.2 bundle version of Fusion and Apache
>> > FDO 3.5
>> > DB MySql 5.1
>> > I attached to this post the error.log and trace.log.
>> > Can anyone help me?
>> > Thanks
>> > Salvatore
>> > http://osgeo-org.1803224.n2.nabble.com/file/n6985005/Trace.log
>> Trace.log
>> > http://osgeo-org.1803224.n2.nabble.com/file/n6985005/Error.log
>> Error.log
>> > View this message in context: http://osgeo-
>> org.1803224.n2.nabble.com/MGOS-2-2-crash-with-WMS-
>> tp6985005p6985005.html
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapguide-users mailing list
>> > mapguide-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
Zac Spitzer
+61 405 847 168
