[mapguide-users] Points from Sql/ODBC data source not showing
Martin Morrison
martin.morrison at edsi.com
Tue Nov 22 12:09:05 EST 2011
Seriously consider moving your data to a 2008 SQL server using a spatial datatype.
Do you have nulls in your current data? Are your extents correct? Do the coordinate system of the point match the map? Indexed?
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA 24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of soudemans
Sent: Tuesday, November 22, 2011 12:04 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Points from Sql/ODBC data source not showing
We are running MapGuide OS 2.2 on a 64 bit Windows Server 2008 R2. And we
are using mapGuide Studio 2.2.06301. I have managed to create a successful
connection to a separate SQL Server 2005, again running on a Windows 2008
Server box, though this one is not a R2.
The intent of the ODBC connection is to display the X and Y coordinates in
the table as points on the map. I have created the layer, included the
layer in the map, checked the data, but alas, no points. I am hoping that I
am missing something simple. Anyone seen this before? Let me know if you
need more information
Thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Points-from-Sql-ODBC-data-source-not-showing-tp7021115p7021115.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
