[mapguide-users] RE: Points from Sql/ODBC data source not showing
soudemans soudemans at ruekert-mielke.com
Tue Nov 22 17:17:32 EST 2011
Martin,
"SQL Spatial gives you the benefits of spatial indexes, ability to
transform coordinates, etc.  It also uses the native driver rather than
ODBC." - That may be true, but that would also require me to rework my
application, something I'd like to avoid if at all possible
"On the extents (assuming no transformations) take the smallest x and y
values and the largest x and y values, that is your extents for that
data.  Do those coordinates fall within the range of your mapguide map?"
-  The coordinates fall within the specified range.
I am checking if this is also a problem with Mapguide Enterprise VS
MapGuide OS.  If it is I can check with Autodesk support.  I will post
any findings here regardless.  I am just hoping this is not going to
turn into some long drawn out affair.  I might just end up following
your initial suggestion after all.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Points-from-Sql-ODBC-data-source-not-showing-tp7021115p7022287.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111122/605b1238/attachment.html
