[mapguide-users] Re: task pane hidden on basic web layout load
    Jackie Ng
    jumpinjackie at gmail.com
    Tue Nov 22 21:35:17 EST 2011
In framesettaskbar.templ the "mainappFrame" frameset has a cols attribute
with a %s
This is set to 0 if the Task Pane is disabled in the Web Layout (ie. The
frame containing the task pane will have a width of 0).
I suppose you could bake in some javascript logic to expand this frame when
the command is executed. There's javascript functions for that
(OpenTaskBar() and CloseTaskBar() in mainframe.templ)
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/task-pane-hidden-on-basic-web-layout-load-tp7022460p7022987.html
