[mapguide-users] RE: Points from Sql/ODBC data source not showing
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Nov 23 17:42:38 EST 2011
Would it be worth anything to try dumping your data into an access database just to test things out (that uses the same odbc fdo)? If you can't get it going with that, then there's got to be some other problem...
Andrew
Sent from iPhone
On Nov 23, 2011, at 5:29 PM, soudemans <soudemans at ruekert-mielke.com> wrote:
> I guess it is time to cut my losses, so I pondered the next dilemma, if I am
> going to put the data in a spatial data base, which will have to be ArcSDE,
> since the client uses MS SQL Server 2005, then how would I add a record and
> point data from the map's interface. How indeed? I checked with our
> resident Arc-spert who gave me one of those "you've got to be kidding looks"
> and then recommended "Don't". This does not mean that it is impossible;
> instead it would be a horrendous work around. I think I mentioned before
> that this should not be rocket science, so I am baffled by the fact that I
> am now considering things like storing the data in XML data sources, or
> finding some other work-around. It is a good thing I am going home in an
> hour to prepare myself for the annual tradition of consuming turkey and
> beer. But if any-one has experience with this and would be willing to share
> I would be much obliged to read whatever suggestions you may come up with.
> In the meantime Happy Thanksgiving to all that celebrate turkey day.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Points-from-Sql-ODBC-data-source-not-showing-tp7021115p7026225.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
This e-mail message (including attachments, if any) is confidential and may be privileged. Any unauthorized distribution or disclosure is prohibited. Disclosure to anyone other than the intended recipient does not constitute waiver of privilege. If you have received this e-mail in error, please notify us and delete it and any attachments from your computer system and records.
Ce courriel (y compris les pièces jointes) est confidentiel et peut être privilégié. La distribution ou la divulgation non autorisée de ce courriel est interdite. Sa divulgation à toute personne autre que son destinataire ne constitue pas une renonciation de privilège. Si vous avez reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel, ainsi que les pièces jointes, de votre système informatique et de vos dossiers.
