[mapguide-users] Re: FDO SQL SERVER SPATIAL - Polygon ring less
than 3 points?
Hans Milling
hm at geograf.dk
Thu Nov 24 02:46:07 EST 2011
Can you show the actual query sent to the SQL server (using a trace or the
like )? It seems that either you have too few points (even though you write
there should be many) or they are at the same x/y lat/lng (perhaps value 0
in all of them?).
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-SQL-SERVER-SPATIAL-Polygon-ring-less-than-3-points-tp7026243p7027326.html
