[mapguide-users] Re: Automatic zoom to selected features
soudemans
soudemans at ruekert-mielke.com
Wed Nov 30 15:18:02 EST 2011
I love it when I get the answer before anyone gets a chance to respond. And
(I think that) this solution is pretty sweet. Some how I came accross the
fact that you could get the extents of the Mg selection. Well as they say,
everything else is history. If you have any questions or comments please do
not hesitate to ask. Solution's code is below.
Protected Sub btnShowMap_Click(ByVal sender As Object, ByVal e As
System.EventArgs) Handles btnShowMap.Click
' Initialize mapguide instance
InitMapGuide()
Dim vMsg As String
Dim map As New MgMap(_SiteConnection)
map.Open(_ResourceService, _MapName)
Dim layer As MgLayer = DirectCast(map.GetLayers().GetItem(_MgLayer),
MgLayer)
Dim qryOptions As MgFeatureQueryOptions = New MgFeatureQueryOptions()
qryOptions.SetFilter(_MgFeatID & " IN(" & GetSelectedIDs() & ")")
Dim FeatReader As MgFeatureReader = layer.SelectFeatures(qryOptions)
Dim vSelection As New MgSelection(map)
Dim vSelExtents As MgEnvelope
Dim vLLeftXY As MgCoordinate
Dim vURightXY As MgCoordinate
Dim vMapHeight, vMapWidth As Double
Dim vLLx, vLLy, vURx, vURy, vCtrX, vCtrY As Double
Dim _MapScale, _CtrPtX, _CtrPtY As String
' Create a mg selection
vSelection.AddFeatures(layer, FeatReader, 0)
' Get the selection's extent
vSelExtents = vSelection.GetExtents(_FeatureService)
' Get the lower left and upper right coordinate points of the extents to
calculate the center
vLLeftXY = vSelExtents.GetLowerLeftCoordinate()
vURightXY = vSelExtents.GetUpperRightCoordinate()
' Get the selection's height and width used to calculate a new scale
vMapHeight = vSelExtents.GetHeight()
vMapWidth = vSelExtents.GetWidth()
' Get the individial values for X and Y for each the lower left and
vLLx = vLLeftXY.GetX
vLLy = vLLeftXY.GetY
vURx = vURightXY.GetX
vURy = vURightXY.GetY
' Calculate the center point X and Y values and convert them to strings
- that is what we need
_CtrPtX = ((vURx - vLLx) / 2 + vLLx).ToString
_CtrPtY = ((vURy - vLLy) / 2 + vLLy).ToString
' Calculate the new map scale. 65500 is the map scale when zoomed to
the map's extent
' 49300 is the heightin feet of the map and 43200 is the width in feet
of the map,
' both when zoomed to the map's extent.
If vMapHeight > vMapWidth Then
' Calculate scale when height of selection envelope is greater than
its width
_MapScale = (((vMapHeight * 65500) / 43200) * 1.1).ToString
Else
' Calculate scale when width of selection envelope is greater than
its height
_MapScale = (((vMapWidth * 65500) / 49300) * 1.1).ToString
End If
' Escape any single quotes
Dim xml As String = selectionSet.ToXml().Replace("'", "\'")
' Build the JavaScript code to set the active selection
Dim s As String = "<script type=""text/javascript""
s += "language=""javascript"" "
s += "for=""window""
event=""onload"">" & vbLf
s += " var main = window.opener.window.opener;" & vbLf
s += " var map = main.GetMapFrame();" & vbLf
s += " map.SetSelectionXML('" & xml & "');" & vbLf
s += " main.ZoomToView(" + _CtrPtX + "," + _CtrPtY + "," + _MapScale +
", true);" & vbLf
s += "</script>" & vbLf
' Use the HttpResponse object to send this code to the client
Response.Write(s)
End Sub
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Automatic-zoom-to-selected-features-tp7047230p7048282.html
