[mapguide-users] Re: Is there any way to print a Map in a vectorial
mode with Fusion?
Jackie Ng
jumpinjackie at gmail.com
Mon Oct 3 03:04:03 EDT 2011
MapGuide only supports DWF and KML as vector output formats. For purposes of
printing/plotting, DWF is the only supported format at the moment.
To plot your map as a DWF, add/modify your SaveMap widget extension
parameters so that:
* Format = DWF
* ResourceId = Resource ID of the Print Layout
Invoking this widget will plot the current view of your map as a DWF using
the specified Print Layout
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Is-there-any-way-to-print-a-Map-in-a-vectorial-mode-with-Fusion-tp6854001p6854041.html
