[mapguide-users] Re: Coordinate system override for SQL Server 2008
Jackie Ng
jumpinjackie at gmail.com
Sun Oct 9 21:35:46 EDT 2011
If a Feature Source's coordinate system does not match your Map Definition's
coordinate system, MapGuide will reproject features from that Feature Source
when rendering.
This applies to *any* FDO provider.
wrt SQL Server 2008, you may need to use ExtendedCoordSys.txt to specify a
CS translation table
see: http://trac.osgeo.org/fdo/wiki/FdoSQLServerSpatialNotes
If you need such a file, an installation of FDO Toolbox
(http://fdotoolbox.googlecode.com) contains such a file.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Coordinate-system-override-for-SQL-Server-2008-tp6870641p6875490.html
