[mapguide-users] I can't display layer from WMS
mgmarek smietnik at purzynscy.pl
Mon Oct 10 06:04:52 EDT 2011
hello everybody,
i'm new at forum.
from over a week i'm trying to display layer with orto photo from wms server
but i get nothing.
i've check this server in quantumgis and everything was ok.
my configuration mgos 2.1 with fusion on windows standard instalation (on
2.2 i've got the same result), maestro 2.5, 3.5, 4.0beta2
wms server: http://sdi.geoportal.gov.pl/wms_orto/wmservice.aspx
my steps are:
1. in maestro i add new feature source as wms provider
2. in wms feature source window:
    a) in feature source field i put:
    b) after test connection - fdo connection status: true
    c) advanced - feature classes i choose othofoto, layer cs: epsg:4326,
save
    d) after test connection - fdo connection status: true
    e) validate give an error: "no primary key defined for class: ......"
but i think that is not important
    f) save new feature source as eg orto
3. next i add new layer as raster layer definition (v 1.0.0)
4. in layer window:
    a) feature source - orto
    b) feature class - WMS_Schema:ORTOFOTO
    c) validation - i've got the same error
    d) save new layer as orto
5. next i add new map definition (1.0.0)
6. in map window:
    a) i add layer orto
    b) i set coordinate system to 4326
    c) after click on button "set view to combined extent ..." i've error:
"could not transform extents of any layer in this map definition ..."
    d) i specify extents manually
    e) validate - the same error as in feature source and layer
    f) save
when i start application (modified aqua template) i've got nothing on the
map.
changing map definition by adding simple vector layer in epsg4326 gives me
in result view of this layer.
i've was trying with another one wms with the same result :(  (in quantum
gis everything was ok)
what i'm doing wrong.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/I-can-t-display-layer-from-WMS-tp6876383p6876383.html
