[mapguide-users] Re: Ajax Viewer support for touch devices
Nadia Spitilli nspitilli at hotmail.com
Wed Oct 12 10:00:34 EDT 2011
Hi Peter,
thank you very much for your help!
I like HTML solution, because it is suitable for all devices.
With the second workaround you develop another kind of viewer, embedded in
an Android App. Probably this solution require more work.
I have seen the button 'GPS Pos'. Which API did you use for this function?
Did you make the same with HTML solution?
Thank you for your sharing
Best Regards,
Nadia
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Ajax-Viewer-support-for-touch-devices-tp6163993p6885116.html
