[mapguide-users] Some details on the default Query Features tool
Jamo
adam.jamison at portbris.com.au
Thu Oct 20 02:20:26 EDT 2011
Hey guys this is not the usual omg it doesn't work post :)
I actually found something out by doing the hard yards !!!!
I have been using a mssql spatial DB that was created some time ago and it
has never had a spatial extents set...
Now insert problem the default search / query was never working correctly
for me until I assigned a coordinate system to it using a method the
coordsysext.txt file....
I've noticed a few people reporting issues with the search function, for me
after I added the coord system everything seems to be working.
I reckon the suspect code is here in query.php
If the getspatialcontexts is returning null maybe it bombs out the search?
I haven't looked at a way to bypass this, perhaps use no transformation and
just take the maps default?
Anyhow just thought I'd let everyone know that might be having issues to
check you have a valid cordinate system defined etc etc
cheers
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Some-details-on-the-default-Query-Features-tool-tp6911776p6911776.html
