[mapguide-users] Error: Failed to stylize layer: An exception
occurred in FDO component. Connect failed
hm
hm at geograf.dk
Thu Oct 27 03:56:44 EDT 2011
Hi All
I just installed Autodesk Infrastructure Studio 2012, but now some of my
layers are not working. The layers not working are all based on
TAB/MAP/ID/IND files. Layers from e.g. SQL Server works fine.
I have added the ORGProvider.dll (and all dependencies) to the bin\FDO
folder. Also ensured that it is FDO3.6 to match the existing version. The
providers.xml also have a reference to the dll.
When I try to preview a layer already created using the TAB/MAP/ID/IND files
I get the following error in the Logs\error.log:
<2011-10-27T09:00:21> 4060 Ajax Viewer ::1 Administrator
Error: Failed to stylize layer: Adresse
An exception occurred in FDO component.
Connect failed:
StackTrace:
- MgMappingUtil.StylizeLayers() line 820 file
d:\build\mge2012\build_42.2\ent\os\server\src\services\mapping\MappingUtil.cpp
When I delete the layer and add it again using Maestro, add feature and
select OSGeo FDO provider for OGR, type the path to the TAB file in the
datasource and push the Test Connection button I get the following error:
<2011-10-27T09:22:52> 5108 MapGuide Maestro v3.5.0.6071 ::1 Administrator
Error: An exception occurred in FDO component.
Connect failed:
StackTrace:
- MgFeatureServiceHandler.ProcessOperation() line 83 file
d:\build\mge2012\build_42.2\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpTestFeatureSourceConnection.Execute() line 100 file
d:\build\mge2012\build_42.2\ent\os\server\src\services\feature\OpTestFeatureSourceConnection.cpp
- MgServerFeatureService.TestConnection() line 234 file
d:\build\mge2012\build_42.2\ent\os\server\src\services\feature\ServerFeatureService.cpp
- MgFdoConnectionManager.Open() line 313 file
d:\Build\MGE2012\BUILD_42.2\Ent\OS\Server\src\Common\Manager\FdoConnectionManager.cpp
- MgFdoConnectionManager.CacheFdoConnection() line 985 file
- MgFdoConnectionManager.Open() line 977 file
Does anyone have a clue what I have done wrong? If you need any more
information I will be happy to share it.
Best Regards Hans Milling
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-Failed-to-stylize-layer-An-exception-occurred-in-FDO-component-Connect-failed-tp6935422p6935422.html
