[mapguide-users] Re: Get the Cursor Position and show tooltip in the toolbar
Jackie Ng jumpinjackie at gmail.com
Thu Oct 27 05:25:06 EDT 2011
The Fusion Map widget wraps an OpenLayers map (accessible through the oMapOL
property of the widget)
So you can register an OpenLayers click handler like this:
http://openlayers.org/dev/examples/click.html
To show a tooltip on a toolbar, you could have a stub InvokeScript widget
that's docked to the toolbar. At runtime, when you have the tooltip, get the
widget by its id and set the label of it's UI object to the tooltip text
(the property of the widget should be uiObj)
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Get-the-Cursor-Position-and-show-tooltip-in-the-toolbar-tp6928041p6935607.html
