[mapguide-users] RE: MapGuide - ArcSDE FDO
GravitaZ jmori at penn-er.com
Thu Oct 27 12:50:02 EDT 2011
I am using the 10.x DLL's currently, It is MS SQL Server
Jonathan Mori | GIS Specialist
Penn E&R, Inc. | 100 Ryan Court, Suite 100 | Pittsburgh, PA 15205
*Cell: 724-689-3757 | * Office: 412-722-1222 | 7 fax: 412-722-1244
* e-mail: jmori at penn-er.com<mailto:jmori at penn-er.com>| * www.penn-er.com  <http://www.penn-er.com/>
From: Crispin_at_Linknode [via OSGeo.org] [mailto:ml-node+s1803224n6937119h2 at n2.nabble.com]
Sent: Thursday, October 27, 2011 12:48 PM
To: Mori, Jonathan D.
Subject: Re: MapGuide - ArcSDE FDO
Not supported but still works from what we have seen with several sites on ArcSDE 10 on MapGuide 2.2 (FDO 3.5).
Though of course, if the data is in Oracle (SDE or SDO, not ST_Geometry - ESRI changing the goalposts) you have options to use the KingOra provider.
Are you using the 9.3 or 10.x DLLs in your MapGuide/Server/FDO folder.
linknode.co.uk<http://linknode.co.uk/>
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/MapGuide-ArcSDE-FDO-tp6913585p6937119.html
To unsubscribe from MapGuide - ArcSDE FDO, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6913585&code=am1vcmlAcGVubi1lci5jb218NjkxMzU4NXwtMjg0NjM3Njk1>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MapGuide-ArcSDE-FDO-tp6913585p6937132.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111027/95179632/attachment.html
