[mapguide-users] RE: QuickPlot and html headers - FYI & request
Mars Wu mars.wu at autodesk.com
Tue Sep 20 21:35:18 EDT 2011
Hi Homan,
I guess you are using the enterprise version of MapGuide 2012 right?
Because Quick Plot uses 127.0.0.1 explicitly to send the HTTP request to get the image from MapAgent, I guess it's why the HTML header binding doesn't work. 127.0.01 is used because in Apache + Java configuration, serverside generated request works only with this IP Address. Localhost or the machine name doesn't work. So if you are not using this configuration, you can manually modify the behind php or aspx file to change 127.0.0.1 to gis.gilacountyaz.gov then it should work.
You can search for 127.0.0.1 in ajaxviewer/quickplotgeneratepicture.php | aspx for Basic Layout or fusion/widgets/QuickPlot/GeneratePicture.php for Fusion to get where the change should be made.
BTW. This problem will be solved in next release of enterprise mapguide.
Thanks,
Mars Wu
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Homan, Thomas
Sent: Wednesday, September 21, 2011 3:39 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] QuickPlot and html headers - FYI & request
I ran into a item that caused QuickPlot to stop functioning for me so thought I'd pass it along
My environment:
MS Server 2008 R2 Standard 64bit
Lots of ram and drive space
IIS7.5
AIMS 2012 - Installed to Default Web Site
I have several websites on this server so decided to use html headers rather than allocating a new IP address or changing port numbers as a means of website segregation. If headers are enabled in the bindings section of IIS then the QuickPlot function does not work and generates the 'The application resources required to generate the plot exceed the settings defined by the administrator' error message. In my case I had my webserver set up to enter AIMS via gis.gilacountyaz.gov/mapserver2012/mapviewerajax/... so set a binding of gis.gilacountyaz.gov thinking I was helping myself. Turns out it I wasn't.
I don't know if anyone else would have a moment to test this error on their server. I don't know if MGOS would exhibit similar loss of functionality. It would be nice to know I'm not the only one with this condition. In my case it was just a matter of editing the bindings then restarting IIS. 5 min in and out.
Regards,
Thomas Homan
Gila County Public Works
GIS Coordinator
1400 E. Ash St
Globe, AZ 85501
phone: 928-402-8515
fax: 928-425-8104
thoman at co.gila.az.us<mailto:thoman at co.gila.az.us>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110921/4c9df43f/attachment.html
