[mapguide-users] Re: how to add an vehicle icon and trace line to
mapguide ?
captainst
quchenxy at yeah.net
Fri Sep 23 23:50:38 EDT 2011
Thank you Gordon.
I have searched a bit on your suggested option. There might be a problem:
the map has to refresh to show the X and Y. If I need to display 20 vehicles
on the map, each with a position update interval of 1~5 seconds, then the
user will always see the map in refreshing state.
I think that in this case I am not able to avoid JavaScript, which shows the
icons/lines on the brower side. To do this I need to use OpenLayer, is that
correct ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/how-to-add-an-vehicle-icon-and-trace-line-to-mapguide-tp6824597p6826430.html
