[mapguide-users] Search for a feature based on feature ID
Tom Weir geekwerks at gmail.com
Sun Sep 25 14:18:38 EDT 2011
Unfortunately, MapGuide is not an app that is easy to learn.
Particularly not on a short schedule.
When I was ramping up to do some C# work, I found the PHP scripts on
this page quite useful:
http://osgeo-org.1803224.n2.nabble.com/Select-features-on-map-load-td3174763.html
The best way to figure out MapGuide is to spend some quality time with
the search engine of your choice; this list, and several blogs have some
really good info, but you need to dig for it. Also, the C# & PHP APIs
are effectively the same in structure, so if you find a sample/snippet
in one language, it is easy to port to the language you're using.
Best of luck,
Tom
