[mapguide-users] Replace sheboygan with some other package!!!!!!!!!!!!
Nishi Pachoree nishipachoree9 at gmail.com
Mon Sep 26 03:54:59 EDT 2011
I have replaced the sheboygan package with the new package using
mapadmin...now when i run the ajaxviewersample.aspx page it displays the
same sheboygan map...i guess the reason is the path
String webLayout =
"Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
in the code ,do i have to change this path on this page as well as
everywhere else ,coz the map is being displayed is of sheboygan only
irrespectice of replacing the package.
On Mon, Sep 26, 2011 at 1:17 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> you know how to load the sheboygan package? both mapadmin and maestro allow
> you to import and export packages
> z
> On Mon, Sep 26, 2011 at 5:44 PM, Nishi Pachoree <nishipachoree9 at gmail.com>wrote:
>> sry but i didnt get you :(
>> On Mon, Sep 26, 2011 at 1:13 PM, Zac Spitzer <zac.spitzer at gmail.com>wrote:
>>> the same way you load a package also allows you to export a package?
>>>   On Mon, Sep 26, 2011 at 5:41 PM, Nishi Pachoree <
>>> nishipachoree9 at gmail.com> wrote:
>>>>   Hi,
>>>> I have installed mapguide server and mapguide webserver extension with
>>>> dotnetviewersample,and sheboygan package.Now i want to replace the sheboygan
>>>> package with my own package so  that i can display a different map ?Can
>>>> anyone advice me where exactly and what changes should i make or what steps
>>>> should i follow to accomplish my goal.
>>>> Thanks and Regards
>>>> Nishi
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer
>>> Solution Architect / Director
>>> Ennoble Consultancy Australia
>>> http://www.ennoble.com.au
>>> http://zacster.blogspot.com
>>> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110926/9e1845e9/attachment.html
