[mapguide-users] [Dwf Viewer] Set selection problem on layers with
same feature class but different filter
Iulia Tamas
iulia_tamas30 at yahoo.com
Thu Apr 5 05:40:20 EDT 2012
Hello,
I have few layers with the same feature class but with different filters.
The SetSelection function is working only for the layer that is the first layer in the MapDefinition Drawing order. For the other layers the xml is created correctly but the layer is not selected on the Map
parent.parent.mapFrame.SetSelectionXML(xmlSelection);
This problem is not reproducing on Fusion viewer.
I am using Mapguide 2.2 64 bit and King Oracle provider
Any ideas?
Thank You,
Iulia
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120405/3f257383/attachment.html
