[mapguide-users] Re: MapGuide 2.4 Beta?
Franz1965 fsozzi at INTERCAD.CH
Thu Apr 12 12:02:58 EDT 2012
Hi All,
I'me trying to use Maestro 4.0rc1 with this Mapguide version, but I can't
open layers.
If I try to open I get:
/Value does not fall within the expected range./
With the further info:
/System.ArgumentException: Value does not fall within the expected range.
   at
OSGeo.MapGuide.MaestroAPI.Schema.DataPropertyDefinition.GetDataType(String
xmlType) in
c:\Workspace\Maestro\OSGeo.MapGuide.MaestroAPI\Schema\DataPropertyDefinition.cs:line
162
   at
OSGeo.MapGuide.MaestroAPI.Schema.DataPropertyDefinition.ReadXml(XmlNode
node, XmlNamespaceManager mgr) in
201
   at OSGeo.MapGuide.MaestroAPI.Schema.PropertyDefinition.Parse(XmlNode
c:\Workspace\Maestro\OSGeo.MapGuide.MaestroAPI\Schema\PropertyDefinition.cs:line
129
   at OSGeo.MapGuide.MaestroAPI.Schema.ClassDefinition.ReadXml(XmlNode node,
c:\Workspace\Maestro\OSGeo.MapGuide.MaestroAPI\Schema\ClassDefinition.cs:line
307
   at OSGeo.MapGuide.MaestroAPI.Schema.FeatureSchema.ReadXml(XmlNode node,
c:\Workspace\Maestro\OSGeo.MapGuide.MaestroAPI\Schema\FeatureSchema.cs:line
161
   at OSGeo.MapGuide.MaestroAPI.Schema.FeatureSourceDescription..ctor(Stream
stream) in
c:\Workspace\Maestro\OSGeo.MapGuide.MaestroAPI\Schema\FeatureSourceDescription.cs:line
58
   at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.DescribeFeatureSource(String
resourceID) in
c:\Workspace\Maestro\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
666
   at
Maestro.Editors.LayerDefinition.LayerPropertiesSectionCtrl.PopulatePropertyList()
in
c:\Workspace\Maestro\Maestro.Editors\LayerDefinition\LayerPropertiesSectionCtrl.cs:line
85
   at
Maestro.Editors.LayerDefinition.LayerPropertiesSectionCtrl.Bind(IEditorService
service) in
46
   at
Maestro.Editors.LayerDefinition.VectorLayerEditorCtrl.Bind(IEditorService
service) in
c:\Workspace\Maestro\Maestro.Editors\LayerDefinition\VectorLayerEditorCtrl.cs:line
54
   at Maestro.Base.Editor.LayerDefinitionEditor.Bind(IEditorService service)
in c:\Workspace\Maestro\Maestro.Base\Editor\LayerDefinitionEditor.cs:line 68
   at Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService
value) in c:\Workspace\Maestro\Maestro.Base\Editor\EditorContentBase.cs:line
81
   at Maestro.Base.Services.OpenResourceManager.Open(IResource res,
IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in
c:\Workspace\Maestro\Maestro.Base\Services\OpenResourceManager.cs:line 164
   at Maestro.Base.Services.OpenResourceManager.Open(String resourceId,
c:\Workspace\Maestro\Maestro.Base\Services\OpenResourceManager.cs:line 220/
Are there any workaround?...
View this message in context: http://osgeo-org.1560.n6.nabble.com/MapGuide-2-4-Beta-tp4553155p4857257.html
