[mapguide-users] Re: map selection problem
Franz1965 fsozzi at INTERCAD.CH
Fri Apr 13 15:57:15 EDT 2012
GordonL wrote
> It might be the path (C:\Program
> Files\AutoDesk\MapGuideEnterprise2011\WebServerExtensions\www\webconfig.ini)
> for the ini for getting your selectionXML is off.
> try to
> alert(selectionXml);
> to make sure you have correct XML.
Generally I write webconfig path in the file system format:
/OSGeo.MapGuide.MapGuideApi.MgInitializeWebTier(@"C:\App\Test\MapGuideSample\MapGuideSample\webconfig.ini");/
But I also tried:
/OSGeo.MapGuide.MapGuideApi.MgInitializeWebTier(@"http://localhost/mapguide/webconfig.ini");/
In general whatever I set in MgInitializeWebTier (also totally wrong path),
it works, but it does not select. I can see my web layout with my map and it
zooms on the right extension, but it does not select (an I have a
selectionXml that looks ok).
View this message in context: http://osgeo-org.1560.n6.nabble.com/map-selection-problem-tp4655687p4879719.html
