[mapguide-users] Re: MgCooker performances
Zac Spitzer
zac.spitzer at gmail.com
Mon Apr 23 22:57:09 EDT 2012
I would suggest on a four core machine, perhaps 8 concurrent requests,
depending on how heavy your map is to render.
anything running in a VM is also going to be a bit slower than a non virtualised
machine, especially whilst running a cpu intensive application
you just need to experiment to see which config ends up driving the
load at close to 100% cpu.
ignore the time estimate and focus on the tiles remaining / throughput,
the current time esitimate reminds me of "microsoft minutes" whilst copying
lots of files.
also mgcooker defaults to 1 concurrent request which means you are
tiling a single tile at a time, which obviously is the slowest approach
available.
z
On Tue, Apr 24, 2012 at 12:50 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Besides adaptation to newer Maestro APIs, the core tile generation logic in
> MgCooker has not changed since the very first release (before I started on
> it).
> The estimation is obviously wrong. I just can't tell you where at the
> moment.
> - Jackie
> View this message in context: http://osgeo-org.1560.n6.nabble.com/MgCoocker-performances-tp4911616p4912237.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
