[mapguide-users] MapGuide 2.2 does not login as Administrator
mongonv erought at e-syncon.com
Fri Apr 27 05:54:57 EDT 2012
Hey All,
I just installed the stable MG 2.2 for windows, using the installer on a Win
2003 server running IIS 6 and everything seems to have installed, but when I
try to login all I get is "Cannot establish connection".
I have gone thru all the posts I can find and have verified that the
mgserver.exe is running, listed as a service and a process, the web server
is running, there is nothing in the logs, I have rebooted, and can't figure
out what may be the issue.
I am using the "Administrator" "admin" login, have copied it from multiple
posts to make sure, and still no luck.
The getting started guide said there was a MgWebServerExtensionsSetupfile
that was to be downloaded and installed, but I could not find anything but
the main mapguide installer on the downloads page.  Is there something else
that has to be installed to get basic functionality working?
Also, the guide shows to use either port 8008 or the port the installer
setup which is 2810 to access the login page and if either is used all I get
is web page cannot be displayed.
http://localhost/mapguide/mapadmin/login.php brings up the login page, but
the login does not work.
Any ideas would be appreciated.
Thanks
View this message in context: http://osgeo-org.1560.n6.nabble.com/MapGuide-2-2-does-not-login-as-Administrator-tp4933468p4933468.html
