R: R: [mapguide-users] Quickplot - how do you get rid of it after you're done?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Apr 27 15:11:13 EDT 2012
Correction: pressing print on the preview does print, but the preview
stays open after. I have to "cancel" to close that. So I wonder if the
bug has something to do with removing the overlays (the preview, the
grey box)? It seems that in my case, they just don't go away...
On 12/04/27 3:55 PM, Andrew DeMerchant wrote:
> Ah - see, I press "generate" and the box just stays there for me
> (behind the preview). Pressing print on the preview closes the
> preview, but the box stays there...
> On 12/04/27 3:47 PM, Francesco Sozzi wrote:
>> I am not sure to understand what you mean...
>> This I what I do and what it happens:
>> 1.I activate Quick Plot
>> 2.A popup is displayed
>> 3.I press "advanced options"
>> 4.A grey box is displayed over the map
>> 5.I can turn the box (to do that I have to set map in a "pan" mode,
>> on "select" mode the rotation seems not working)
>> 6.I press "generate" button on popup (which, in the meantime, is gone
>> under the Mapguide windows)
>> 7.Gray box disappears and preview box is displayed
>> 8.I press "print" on the preview box
>> *Da:*mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *Per conto di *Andrew
>> DeMerchant
>> *Inviato:* venerdì, 27. aprile 2012 19:41
>> *A:* MapGuide Users Mail List
>> *Oggetto:* Re: R: [mapguide-users] Quickplot - how do you get rid of
>> I'm still on the first preview release too - when does that box go
>> away for you?
>> On 12/04/27 2:39 PM, Francesco Sozzi wrote:
>> This is strange. At my site it works as expected, but I'm still on
>> the first test mapguide 2.4 released. I don't know if something is
>> changed in the meantime.
>> <mailto:mapguide-users-bounces at lists.osgeo.org>
>> DeMerchant
>> *Inviato:* venerdì, 27. aprile 2012 19:11
>> *Oggetto:* [mapguide-users] Quickplot - how do you get rid of it
>> after you're done?
>> This is likely a stupid question, but how do you get rid of the Quick
>> Plot box (the one that lets you rotate and move the area to be
>> plotted - it shows up via the advanced options)? So far, the only way
>> I can get rid of it is to reload the whole page....
>> GEMTEC Limited <http://www.gemtec.ca/>
>> *Andrew DeMerchant*
>> tel: 506.453.1025  /  toll-free: 1.877.243.6832
>> fax: 506.453.9470
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org  <mailto:mapguide-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> *Andrew DeMerchant*
>> fax: 506.453.9470
> *Andrew DeMerchant*
> fax: 506.453.9470
*Andrew DeMerchant*
fax: 506.453.9470
Skipped content of type multipart/related
