R: R: R: [mapguide-users] Quickplot - how do you get rid of it after you're done?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Apr 27 20:57:56 EDT 2012
Not quite. I mean the grey box never goes away - ever...and the preview box only goes away when I hit cancel (which is fine). The big problem is the unremovable grey box...
Sent from my iPhone
On 2012-04-27, at 5:01 PM, "Francesco Sozzi" <fsozzi at intercad.ch> wrote:
> Ah ok, you mean the preview box does not disappear after printing (you have to press cancel to remove the preview box). This happens also to me, but I think it is his normal behavior.
> Take a look here: http://213.133.229.149/mapserver2012/mapviewerajax/?WEBLAYOUT=Library://TBDemoBlonayCan/BasicLayout.WebLayout
> user=demo, pswd=demo
> It is a very simple example I’ve done on AIMS.
> Da: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Per conto di Andrew DeMerchant
> Inviato: venerdì, 27. aprile 2012 21:11
> A: MapGuide Users Mail List
> Oggetto: Re: R: R: [mapguide-users] Quickplot - how do you get rid of it after you're done?
> Correction: pressing print on the preview does print, but the preview stays open after. I have to "cancel" to close that. So I wonder if the bug has something to do with removing the overlays (the preview, the grey box)? It seems that in my case, they just don't go away...
> On 12/04/27 3:55 PM, Andrew DeMerchant wrote:
> Ah - see, I press "generate" and the box just stays there for me (behind the preview). Pressing print on the preview closes the preview, but the box stays there...
> On 12/04/27 3:47 PM, Francesco Sozzi wrote:
> I am not sure to understand what you mean…
> This I what I do and what it happens:
> I activate Quick Plot
> A popup is displayed
> I press “advanced options”
> A grey box is displayed over the map
> I can turn the box (to do that I have to set map in a “pan” mode, on “select” mode the rotation seems not working)
> I press “generate” button on popup (which, in the meantime, is gone under the Mapguide windows)
> Gray box disappears and preview box is displayed
> I press “print” on the preview box
> Inviato: venerdì, 27. aprile 2012 19:41
> Oggetto: Re: R: [mapguide-users] Quickplot - how do you get rid of it after you're done?
> I'm still on the first preview release too - when does that box go away for you?
> On 12/04/27 2:39 PM, Francesco Sozzi wrote:
> This is strange. At my site it works as expected, but I’m still on the first test mapguide 2.4 released. I don’t know if something is changed in the meantime.
> Inviato: venerdì, 27. aprile 2012 19:11
> Oggetto: [mapguide-users] Quickplot - how do you get rid of it after you're done?
> This is likely a stupid question, but how do you get rid of the Quick Plot box (the one that lets you rotate and move the area to be plotted - it shows up via the advanced options)? So far, the only way I can get rid of it is to reload the whole page....
> <image001.png>
> Andrew DeMerchant
> tel: 506.453.1025  /  toll-free: 1.877.243.6832
> fax: 506.453.9470
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> <image001.png>
> Andrew DeMerchant
> fax: 506.453.9470
> <image001.png>
> Andrew DeMerchant
> fax: 506.453.9470
> <image001.png>
> Andrew DeMerchant
> fax: 506.453.9470
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120427/61039a81/attachment.html
