[mapguide-users] Create Layer from MySQL Database Table
Jackie Ng
jumpinjackie at gmail.com
Mon Aug 6 00:06:02 PDT 2012
Try connecting to the MySQL db using the ODBC provider as that is the only
provider that lets you configure Feature Classes from tables with X/Y/Z
columns.
You also have to use 4.0.2 or a newer release as ODBC configuration support
was broken before then.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Create-Layer-from-MySQL-Database-Table-tp4992647p4993292.html
