[mapguide-users] Step by Step for ECW and MGOS 2.4
Trevor Wekel
trevor_wekel at otxsystems.com
Wed Aug 15 22:20:23 PDT 2012
Hi Gordon, Steve, Jackie,
The release-1400-gdal series is built with Visual Studio 2005. See http://www.gisinternals.com/sdk/ for more information.
Try using the following binaries - they should be built using GDAL 1.9.0 and Visual Studio 2010.
32bit MapGuide 2.4 http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1600-gdal-1-9-0-mapserver-6-0-1.zip
64bit MapGuide 2.4 http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1600-x64-gdal-1-9-0-mapserver-6-0-1.zip
The latest "1600 series" GDAL 1.9.1 binaries may also work assuming API compatibility between GDAL 1.9.0 and GDAL 1.9.1.
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: August 15, 2012 11:00 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Step by Step for ECW and MGOS 2.4
Here's your checklist for GDAL:
- The GDAL version with ECW support must be 1.9
- It must be built with MSVC 2010
- It must be of the same bitness as your MapGuide/FDO
MGOS 2.4 RC1 is using a GDAL FDO Provider built against GDAL 1.9. So if that
site offers an ECW-enabled version of GDAL that matches the above
parameters, the existing wiki instructions should hopefully still work.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Step-by-Step-for-ECW-and-MGOS-2-4-tp4995445p4995528.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
