[mapguide-users] Thematic maps on Non Spatial Data
Zac Spitzer
zac.spitzer at gmail.com
Sat Aug 18 03:15:12 PDT 2012
Mapguide renders data from a fdo data source, so your widget needs
to create/populate a temp datasource and then create or update a layer
which will then render off that datasource.
the datasource could be a session based SDF / sqlite, or it could be
a db table with a session key
why don't you want to use joins? if you do this in postgres, you
can use a database view which has no performance problems
On Fri, Aug 17, 2012 at 7:33 PM, nandankishorks
<nandakishorks2010 at gmail.com> wrote:
> Ya, but...!!!
> -Nandan
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Thematic-maps-on-Non-Spatial-Data-tp4994300p4995893.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
