[mapguide-users] API Change in MG 2.4 also Affects PUT in GeoRest?
GordonL
gordon.luckett at arrowgeomatics.com
Wed Aug 22 11:02:20 PDT 2012
Hmm, I don't actually see a build for GeoRest on
http://code.google.com/p/georest/downloads/list
I decided to try using the AIMS 2013 GeoRest and the same result.
gordon
ps. testing procedure:
1. Modify C:\GeoREST\conf\Sheboygan\Property\restcfg.xml with XML
PUT/DELETE/POST options and point to
Library://Samples/Sheboygan/Data/Parcels.FeatureSource
2. Create a user called "Markup" with password "markup" and give authoring
priv.
3. Create an HTML page to "PUT" an update into the Parcels.sdf
the response text says updated, but the data is not....
View this message in context: http://osgeo-org.1560.n6.nabble.com/API-Change-in-MG-2-4-also-Affects-PUT-in-GeoRest-tp4996809p4997126.html
