[mapguide-users] Problem of selection with SQLite data in
Tiphaine SCHMITT tschmitt at geomapgis.com
Mon Aug 27 01:17:07 PDT 2012
I've installed the 2.4 RC1 and my problem is resolved!!
Thank you,
Tiphaine Schmitt
-----Message d'origine-----
De : mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] De la part de mapguide-users-request at lists.osgeo.org
Envoyé : samedi 25 août 2012 21:00
À : mapguide-users at lists.osgeo.org
Objet : mapguide-users Digest, Vol 68, Issue 21
Send mapguide-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	http://lists.osgeo.org/mailman/listinfo/mapguide-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	mapguide-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of mapguide-users digest..."
Today's Topics:
   1. Re: Problem of selection with SQLite data in	MapGuide
      (Zac Spitzer)
   2. Problem in loading data (ilyasselk)
Message: 1
Date: Sat, 25 Aug 2012 23:46:51 +1000
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Subject: Re: [mapguide-users] Problem of selection with SQLite data in
	MapGuide
Message-ID:
	<CAArGWaQiGjGwmpZ6+e+AKnYwphjSqEvnina9GUyoBroGK9dsng at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Can you try this file with 2.4 RC1
http://trac.osgeo.org/mapguide/wiki/Release/2.4/Notes ?
z
On Sat, Aug 25, 2012 at 12:51 AM, Tiphaine SCHMITT
<tschmitt at geomapgis.com>wrote:
>  Dear all,****
> First of all, i?m a new member of this mailing list and I?m working
> for Geomap Services in Chamb?ry, France.****
> I am currently working with a SQLite Database connection in MGOS 2.2
> and I?m facing a problem of selection with a specific table. ****
> The problem occurs with the selection action done in the Maestro 4.0
> viewer (same problem with others versions). When  I try to select some
> objects I see an anarchic selection in the map which does not
> correspond to my action (cf. screenshot below). ****
> The table has been imported in SQLite from an Oracle database with
> others similar tables. The problem only occurs with this table while
> the others are working fine. The parameters of the MG FeatureSource
> and the content of the geometry_columns table in SQLite are exactly
> the same between the
> tables.****
> The selection action works fine in Autocad Map which makes me think
> that the error does not come from my data. The error.log does not give
> any information about this situation and no error message occurs. ****
> Here below, the Data connection screenshot.****
> Does anyone has already encountered this problem?****
> Thanks in advance for your support.****
> Best regards,****
> Tiphaine Schmitt****
> *Ing?nieur d?Application*
> Savoie Technolac                                     Direct : +33 (0) 4
> 79 25 38 66****
> 48 av du Lac du Bourget                      Mobile : +33 (0) 6 27 44 66
> 65****
> Le Square A 17 - BP 210                     General : +33 (0) 4 79 25 38
> 80  ****
> 73374 Le Bourget du Lac                            Fax : +33 (0) 4 79 25
> 38 70****
> http://gs-web.geomapgis.com****
> [image: Description : Description :
> http://www.geomap-services.com/web/styles/gs/imgs/gs_150x54.jpg]<http:
> //www.geomapgis.com/web/geomap-services/>
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120825/bed5334e/attachment-0001.html>
Message: 2
Date: Sat, 25 Aug 2012 10:38:03 -0700 (PDT)
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Problem in loading data
Message-ID: <1345916283612-4997839.post at n6.nabble.com>
Content-Type: text/plain; charset=us-ascii
Hi everyone,
i have  a problem when i load projet, i have this bug message:
The remote server returned an error: (559) MgDbXmlException.:
An exception occurred in DB XML component.
Error: XML Indexer:  Parse error in document at line, 15, char 17. Parser
message: Element 'BackgroundColor' is not valid for content model:
'((Name,CoordinateSystem,Extents,BackgroundColor,Metadata,MapLayer,MapLayerGroup),BaseMapDefinition)'
So,If everyone have any suggestion ???
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-in-loading-data-tp4997839.html
End of mapguide-users Digest, Vol 68, Issue 21
