[mapguide-users] API Change in MG 2.4 also Affects PUT in GeoRest?
Jackie Ng
jumpinjackie at gmail.com
Wed Aug 29 07:00:10 PDT 2012
Just because the APIs for MGOS 2.4 and AIMS 2013 may look the same when
interfacing from .net/Java/PHP code, this is not necessarily the case when
interfacing from C++ code. I wouldn't be surprised if it's some C++ problem
like a vtable mismatch.
So yeah, probably do need a 2.4 targeted build of GeoREST to be absolutely
sure.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/API-Change-in-MG-2-4-also-Affects-PUT-in-GeoRest-tp4996809p4998613.html
