[mapguide-users] Is it possible to specify the schema version when connection to a WMS feature source?
von Wartburg, Jan BKSD Jan.vonWartburg at bl.ch
Mon Dec 10 02:41:51 PST 2012
Hello All,
With Maestro 4.0.4 I am trying to set up a new WMS feature source. I keep getting error messages in the MGOS 2.2 error log (see below) when trying to show a WMS layer from this feature source in the browser.
In ArcGIS 9.3 I was initially getting very similar error messages with this same WMS feature source. In ArcGIS one can choose the WMS schema when connecting to a WMS server. After having switched from 1.3.0 to 1.1.1 in ArcGIS everything worked fine there.
So my question: Is it possible in Mapguide/Maestro to choose the WMS schema version when connecting to a WMS server that offers both schema versions?
I didn't find anything in the configuration document of the WMS feature source.
Thanks and regards,
Jan
<2012-12-10T11:15:12>  5240 Ajax Viewer 127.0.0.1 Administrator
 Error: Failed to stylize layer: WMSneu2
        An exception occurred in FDO component.
        InvalidFormat:
        msWMSLoadGetMapParams(): WMS server error. Invalid format application/vnd.ogc.se_xml for the EXCEPTIONS parameter.
        msShapefileOpen(): Unable to access file. (/var/www/vhosts/xxxxx/private/xxxx/mapserver/)
        msShapefileOpen(): Unable to access file. (/var/sig/xxxxx/shp/)
        msShapefileOpen(): Unable to access file. (/var/www/vhosts/xxxx/private/xxxx/mapserver/)
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121210/508570e2/attachment.html>
