[mapguide-users] Map get all crazy when scolling after unsing the
ZoomToView function
Gabriele Monfardini
gabrimonfa at gmail.com
Fri Feb 3 09:59:27 EST 2012
> After I use the ZoomToView function in my PHP code, if I try to scroll in or
> out, or muve the map it sends me to coordinate 0,0.
Check that you are passing float number coordinates and an integer for
scale to ZoomToView,
For instance in JS you may use ParseFloat and ParseInt.
Regards,
Gabriele Monfardini
