[mapguide-users] Select Within with polygons
von Wartburg, Jan BKSD Jan.vonWartburg at bl.ch
Fri Feb 10 04:14:46 EST 2012
Hi all,
In my SDF feature source there are round polygons that were created from polylines with curved segments. They are normally selectable in the AJAX viewer, but if I want to use the Select Within command with one of these polygons, there is no result even if there are elements on the chosen layer within the polygon.
The selection (setselection.php) is empty.
My only solution so far is to convert those polylines to polylines with linear segments before exporting the objects to the SDF.
Is this a bug of MGOS 2.2? Has anyone encountered the same problem and found a more elegant solution than me?
Regards,
Jan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120210/04fd548d/attachment.html
